RCU Forums - View Single Post - Kill Switch or Power Loop Plug
Old 07-30-2008 | 05:18 PM
BACKEMF's Avatar
BACKEMF
Default RE: Kill Switch or Power Loop Plug
Yo, here is what I did.
Heavy 10 guage wire, dual leads for 2P, worked into a single 8mm bullet connector on the deck. I got the connectors from HobbyKing, AKA HobbyCity.
They also have 10G waire.
I used carbon fiber, but I do not suggest it for this application, wood or fibergalss is fine. CF conducts electricity but I made 100% shure I would not have problems. In hindsight I wouldn't use it again.
If you only run 1P, then you use less wireand 5.5 or 6mm plugs will do fine.
My wires are a bit long, again hindsight is 20/20.
ID:	1000916   Click image for larger version
ID:	1000917   Click image for larger version
