RCU Forums - View Single Post - ECU Programming ?
Old 07-30-2008 | 07:05 PM
DavidR
Default RE: ECU Programming ?
ORIGINAL: Harley Condra
Reading your post indicates you already have an engine, so why don't you read the manual for the procedure for you engine?
Harley Harley Harley........reading the manual is for sissys!!!!
It is always a good idea to re learn the ECU after changing parameters, may not be necessary but it only takes 30 seconds so why not.
BTW the stick on the left controls the max RPM why not just use it???
DR
