ORIGINAL: DavidR
ORIGINAL: Harley Condra
Reading your post indicates you already have an engine, so why don't you read the manual for the procedure for you engine?
Harley Harley Harley........reading the manual is for sissys!!!!
It is always a good idea to re learn the ECU after changing parameters, may not be necessary but it only takes 30 seconds so why not.
BTW the stick on the left controls the max RPM why not just use it???
DR
David said, "BTW the stick on the left controls the max RPM why not just use it???"
I like his thinking..
When you get in your car in the morning to drive to work....nobody pushes the throttle to the floor and leaves it there until they park it at work now do they? Same thing with the throttle stick...it's better to have the power and not need it than to need it & not have it!
Don
