Took out the engine , flush out all the fuel inside the engine ..... funny thing is when i took off the header there is fuel dripping out from the header , i mean alot ....
after hours of working , place back the engine to my plane n strat again , well it START RUNNING !! But when i took off the glow plug it just stop .
The second start , with the glow ignitor on it will idle low ... but when remove the glow ignition it stop again , it seems like too rich for the low end . Alot of white smooke !
The 3 start , move the trottle stick up abit to run'higher idleing' and took off the glow plug ...... run for 6 sec it stop again !!
Do i need to adjust the reg ccw about 1/2 turn to 1 turn to lean the low end for better idle ! ??
Thank you guys , for all the help
can get much help around my site , very few pattern flyer here with 2m plane ..... so , really really looking forward to all your reply ,
Thanks for the help !
