RCU Forums - View Single Post - MVVS 91
Thread: MVVS 91
Old 07-31-2008 | 08:17 AM
pe reivers
Default RE: MVVS 91
Once the engine is run in, and the needle is set well, you will never have to readjust it. That being the case, you can use locktite to fix the needle in place so it will not budge unless you want to. At the same time the method prevents any air leaks.
Fly Low71 (09-23-2025)
