RE: FLy Eagle Jet Models
Woops your right. I ordered the 1 inch rams from air power which is close to 25 mm not 10mm as I posted. All I did was simply measure the stroke of the existing rams on the FEJ F16.
If need you can still adjust with collars or stoppers to fine tune the travel. I just hope the diff hole size can be easily fixed which I am sure can be.
Vince, you may struggle with 10mm troke!
Mav[8D]
