Scale strut material?
If your struts are to be functional make sure the ends are secure & won't pull out or vibrate enough to fracture. Also give some extra thought to the anchor points in wing & fuselage . I have found out that you only get one strut failure per aircraft ! It's not pretty! MAX H.
