RE: what the???????
2 1/2 turns (full turns not 2 1/2 half turns) out on the low and flush on the high. 1mm idle. no air leaks glow plug fine. doesn't even try to fire. turn the high almost all the way in and it will fire but die if you try to give it throttle. fuel is pumpin out the exhaust either way. what's the deal? I'm now officially at a loss. PLEASE HELP..................
