ORIGINAL: brel
the next thing is to install the Elmod gear to run with the HL boards, as finances permit, I cannot see the point of throwing away a transmitter when it works OK and adding the expense of getting another one and the receiver as well
Are you going to keep the airsoft gun? If not, you may want to consider lengthening the gun barrel by 30~33mm. It'll make the Pershing looks MUCH nicer...
