RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
use the black caps on the one you DO want, plug it into the "TH" plug (3 wire plug coming from the ESC) make sure the orange wire is on the "P" and brown is on the "-", red of course on the "+".
turn on ESC (power up the car) the red light flashes for a milisecond. then, nothing for ~ 3 seconds. then, once the red light on the card is steady, turn off power to car. unplug card, plug ESC back into Rx, and power car back up.
lather, rinse, repeat.
(i would use "soft braking", "reverse yes", and "2s" if i were you, so put the black caps on those selections.)
also, FYI, there is an instruction manual included with the setup, you may want to read it :P
