ORIGINAL: Gordon Mc
(2) Per the AMA bigwigs, if you are an AMA member you are required to follow all AMA rules at ALL times, not just when you feel like it – in which case an AMA member flying a turbine without a waiver is not "fine" just because he's flying from a private field. (I'm not saying that's how things SHOULD be – just that that's how they ARE according to the AMA).
So even if you are an AMA member and have your own private airfield, the AMA will not allow you to fly a turbine?
I thought you needed a waiver only if you planned on flying on AMA sanctioned fields?
