RE: NitroModels .25 Cub
The .25LA should be fine.
The plane will have some trainer like characteristics, but remember that it has no dihedral, and may snap on you.
BTW: The manual pages are ONLINE if you want to see....
However the online manual does not seem to correspond to the pictured plane ( which is NOT unusual ), especially in the gear area and the cowl.
On the pictured plane it looks as if you have to construct ( solder ) the gear assembly to get it to look remotely like the picture. The cowl also does not have the faux engine heads.
