RCU Forums - View Single Post - plastic compatible threadlosk
Old 08-02-2008 | 11:03 AM
sportflyer-RCU
My Feedback: (35)
Default RE: plastic compatible threadlosk
For my application I am using it on metal to metal . I am only concerned whether it will cause the plastic servo arm to deteriorate over time because I am sure the threadlock will wick into the servo arm hole . I will use medium c/a instead. BTW Loctite 425T ( Assure surface curing threadlock ) is supposed to be compatible with plastics . http://www.ellsworth.com/display/pro...5&Tab=Vendorss
