RE: GP Super Stearman
Shubova,
If the wing is lower in the back than in the front you have Positive Incidence, for the wing to be negative the leading edge would have to be lower than the trailing edge. So you would raise the T/E and lower the L/E until you get -1 1/2 degrees. Just curious, has any one checked to see if the techical iinformation available from Great Planes gives the incidence.
