RE: Blade CX control issues
Could be you need to adjust your "pots", or you have a bind in one of your shafts. Making it slower for that blade, and making the yaw happen...
Hope this helps,
~ Jeff
Also check gear mesh. Not to tight. Everything must work freely together, and good to lube up some of those crucial areas also....Tri-Flow, or some gun oil work great.
