ORIGINAL: DRAGONFIRE81M
the shorter the better if you can . it will lower the rescestins. and help with runtime and temp's this is also true on the battery leads . the only wire you dont wont to cut is the anttina
I dont know what you guys do, but I actually extended my antenna wire, now with some piano wire and a bit more rx wire, mines 48" long, it got rid of a lot "noise" I think thats what you'd call it.
but yeah keep the motor wires short, same holds true for the battery wires.
