RCU Forums - View Single Post - hbk2 response
Old 08-03-2008 | 01:55 PM
funflier
Default RE: hbk2 response
the Esky cnc swash is lubed and sealed from the factory with grease that seeps out. Just wipe it off with a Qtip. Do not oil it as it is packed with grease and will wash the grease out. Oil the main shaft though where the round ball bushing passes through it and above where the washout is. All the bearings on the arms are greased for life and need no lube.
