Pull pull tention
Hi,
I have pull pull rudder installation on my 90 size, and i want to make sure that the cable tension is ok.
in the curren setup the centerning isk ( 1mm devation around the center ), and the cables looks tight.
but i can move the rudder against the servo for about few degrees for each side any suggestions ?
