Originally posted by ALLISONMO2
i don't know if the slipper clutch will affect this or if the gear mesh is just too wide.
that is WAY too loose.
stick a peice of paper in the gear mesh and push it tight. lock it down then remove the paper. that should get you the correct mesh
it should spin freely but if you hold the spur and rotate the clutch you should only get a tiny fraction of play.
