RCU Forums - View Single Post - spur gear stripping in st-15
Old 05-19-2003 | 05:39 PM
*Crash*Johnson*'s Avatar
*Crash*Johnson*
My Feedback: (7)
Default Re: Re: spur gear stripping in st-15
Originally posted by Unstable
that is WAY too loose.
stick a peice of paper in the gear mesh and push it tight. lock it down then remove the paper. that should get you the correct mesh
it should spin freely but if you hold the spur and rotate the clutch you should only get a tiny fraction of play.
Dam dude, you are super good at photoshop!
