RCU Forums - View Single Post - Antenna wire
Thread: Antenna wire
Old 08-04-2008 | 05:59 AM
jetmech05
Default RE: Antenna wire
in the second diagram the antenna is folded back on itself,,,in the first diagram the antenna is routed around the inside of the fuselage...I have an aircraft that I ran the antenna down on side of the fuse, up the last rib over the top and back down and along the other side of the fuse for an inch or 2 ....no problems
