YS61 LS
I read before that the YS61 can be used for a plane set up. I am wondering if this is correct because the shaft seems a little short to clear the prop hub when you also need to attach a washer to it. Do I need to do any mods or use any adapter? If it can be done then what sort of a prop would be good for a fast plane? Thanks!
