RE: DZY Engines
Tom, is the DZY 100 prop hub bolt pattern the same as the DA 100? I ask because there are some Chinese twins coming with a prop bolt pattern that's different from anything else, and this makes prop sharing with your other engines impossible and causes you to have to buy new props.
