RCU Forums - View Single Post - Pull pull tention
Old 08-04-2008 | 09:30 AM
apereira's Avatar
apereira
Default RE: Pull pull tention
It's ok, there is not that much tension on it any way,you have to increase the tension a little at a time and check, if you do it like that you will get the correct tension and that's ok with the servo, remember the output shaft has one or two bearings and it can handle a lot more tension.
Regards
