ORIGINAL: brett65
Looks like you have some slack or something in your control lines. If you have a pull-pull cable rudder system, make sure you have the cables tightly adjusted when at neutral.
Ahh.... yes I did noticed my pull-pull rudder lines were a bit slack after the flight. I will tighten them up again. Thanks!
