RCU Forums - View Single Post - Alpha 40 Trainer
Old 08-04-2008 | 01:24 PM
  #32
mwoodman
Default RE: Alpha 40 Trainer
ORIGINAL: mclina
ORIGINAL: mwoodman
I read this post with a great deal of interest, as I have just purchased the Alpha 40 RTF, and am preparing for my initiation into this exciting new hobby. I do have a couple of questions tho:
1. Should the plane always be flown with the suppled 3 blade prop (10.5 x 4), or once competent, is there an off the shelf prop that will "enhance" the performance?
2. The only plug listed as compatible is the Hangar 9 2-cycle super plug, and the information on that plug seems to be sparse. Can anyone recommend a different plug to run with it?
Thanks in advance for the help
Once I soloed mine, I started using 11x6 APC props. I use the Great Planes spinners with the aluminum backplates. You will notice a huge performance increase with the new prop. The 3 blade props that H9 puts on them really slows the plane down well. They just get expensive if you break a few.
You can pretty much use any plug. I can't remember the ones I use off the top of my head. I'm thinking they are OS 8's?
Good luck.
How do u find out what size spinner to install with a 2 blade?
Thanks for all the useful comments so far, I am sure I will have a bunch of questions as time progresses
