RCU Forums - View Single Post - replacement for rubber grommets on servos
Old 08-04-2008 | 10:00 PM
MetallicaJunkie's Avatar
MetallicaJunkie
Default RE: replacement for rubber grommets on servos
i have used a servo screw with a washer for surface area with out grommets, never had a problem with the servo, if you wanted to you could use a couple of layers of bicycle tire patch cut to size to somewhat isolate the servo from vibration
