RCU Forums - View Single Post - Fuel Delivery Problem with Long Narrow Tank
Old 08-04-2008 | 10:02 PM
Villa's Avatar
Villa
Default RE: Fuel Delivery Problem with Long Narrow Tank
Are you using muffler pressure on he new tank? I would expect things to be OK the way you described it. It may need slight adjustment of both fuel valves. Will it run wide open holding the nose vertically up, or at least at 45 degree up?
