RE: size of o-ring ?
It will be metric, the size will be very hard to get as they use custom made 'O' rings and you will have to look around alot. the dia and thickness are not normal 'O' ring size. Either the thickness is wrong or the ria will be wrong for a standard 'O' ring. They use extra thin series 'O' rings that are not easy to come by.
Cheers
