RCU Forums - View Single Post - G26ei-do i need the veloscity stack ?
Old 08-05-2008 | 12:13 AM
tkg
Default RE: G26ei-do i need the veloscity stack ?
Absolutely, maybe.
V-stacks are part black magic. Some times it runs much better some time it runs worse.
It you plane shows fuel/oil dribbles on the carb side then most likely the answer is yes you need a v-stack.
