RCU Forums - View Single Post - This can't be true...
Old 05-18-2003 | 05:30 AM
Grampaw
Default This can't be true...
If you opt to use the wood mounts be sure to seal them really good before mounting and running the engine. If not before long you'll find a soggy mount and a vibrating engine.
If you use a "store bought" mount you will probably have to beef up the firewall somewhat. Either way make sure you have a good solid mount for your engine.
