Wood mounts are still commonly used in very competitive C/L stunt planes. Often, however, aluminum or glass-filled pads are used between the engine and the bearers to prevent crushing the wood. The pads are not difficult to make, but it may require you to do some modifications in order to keep the engine thrust line where you want it.
Good luck, Dzl
