RCU Forums - View Single Post - This can't be true...
Old 05-20-2003 | 01:11 PM
r1morris
Default This can't be true...
I still build some aircraft with Wood engine mounts. Most of the time the wood beams have some good aircraft ply for the actual engine mount. One thing that is a must is to seal the wood as others have said. I use thinned epoxy and have never had a problem.
Old Goldberg kits would bolt the plywood engine mount to the side wood beams this method worked well.
