RCU Forums - View Single Post - hpi e10 mazda rx-7. is it any good???need help quick!!!
Old 08-05-2008 | 07:04 PM
  #43
phmaximus's Avatar
phmaximus
Default RE: hpi e10 mazda rx-7. is it any good???need help quick!!!
i love my E10, cant fault it at all, ive had no problems with it at all. I got mine in kit form with out electronics & carefully put it together. its the ae86 levin and i got it for drifting. it has no problem spinning the wheels & drifting & i think it handles good easy to controll during a drift, only things i found with it are i think the stock springs are to hard & the chassis has a bit of flex, but its not really a problem. i noticed u cant adjust the camber & toe, but out of the box thay seem to be set right, i do like the other tuning ability u can adjust the caster, lots of tyres & foam combos to pick as well as lots of diffrent springs to get. mine is running all hpi parts like: saturn 27t motor, TF-10 transmitter, RF-10 reciver, SF-2 servo, SC-15 esc, 327 light controller, 3400mAh batt, sway bars, alloy drive shaft, CV axles, ball bearing kit, & waiting on the alloy screws, alloy collets & allow shockers. all i want to do to it now is get the alloy strut brace & the locked front diff
