RE: NEW KMP 95" B-25
hi Guys:
Ok, so good news and bad news..... the new wing panels for the new B-25's won't fit the exhisting B-25s because the wing tube location may be moved and the angle of both root ribs may be different than the one's out there today. The new tubes we will provide will not in anyway need bending to make things fit perfectly. There will be a two part tube sytem sliding into the exhisting holes. If anything this area will now be stronger as there will be additional glass tubes inserted (and epoxied) into each other. With regards to the very small gap the bottom of the wing (resulting from the change in angle) I am recomending adding some microballons to the epoxy and I will provide all our customers at our expense with matching paint and the area will be absolutely unnoticeable. [8D]
