RE: NEW KMP 95" B-25
If you draw a vertical line on the center front view of the fuselage and cross it at 90 degrees to each wing tip you will have the correct position of the bottom of the outboard wings. The top of the wings looking from the front, taper from outboard of each nacelle to the tips giving the allusion of having a slight amount of droop . This was taken from the Pacific Prowler B-25.
