ORIGINAL: Minnreefer
How does it turn over with the glow plug removed?
ABC-type engines should feel tight even with the glow plug removed. There'll be a pinch at TDC, which gets a bit less noticeable as the engine gets some time on it. It's best for the engine not to sit there and play with it, turning it over and over through the pinch. ABC-type engines need to be at operating temperature for the cylinder fit to be correct.
