RCU Forums - View Single Post - Albatros DV scratchbuilt.
Old 08-06-2008 | 09:58 AM
ZoomZoom-RCU's Avatar
ZoomZoom-RCU
Default RE: Albatros DV scratchbuilt.
Thanks! By the way, I wanted to correct a mis-statement in the previous description as to the power plant on this machine. It is not a Magnum, as was first intended, but an OS56-A, which is quite frankly an amazing engine. The Magnum was simply too problematic, and had to be changed out in favor of the OS. My recommendation to anyone who is going through the decision making process of what engine to choose for a scale craft, that is reliable and can be hand started.....Go with the OS! Save yourself unwanted grief and expense. The Magnum might be fine on a craft where you can get at it to fool with it constanlty, as well as use a starter to coax it into running. But for this kind of scale application....go with the OS. I thought I'd be saving money by trying the Magnum.....it cost me more than I saved. Ignore at your expense, but maybe this might help somone here.
ZZ.
