ORIGINAL: MinnFlyer
I slide the antenna through a piece of inner pushrod tubing and tie a knot in the end.
Then just slide the tubing down the fuse and let any excess lay in the radio compartment (on a 60-size plane there won't be much excess).
So there is no problem keeping the antenna inside the airframe at all?
I think that is the cleanest way to do it, and easy right now, but no problems with reception ect?
