RCU Forums - View Single Post - Need some Lipo advice
Old 08-06-2008 | 05:32 PM
mkiiina
Default RE: Need some Lipo advice
mah is what determines your runtime length. the higher the longer. the reason the 2s+ will kill your motors is because you will be running them at a much higher voltage than what the motor and possibly the speed contol can handle. simply put you will zap them with too much power.
