RCU Forums - View Single Post - Super Skybolt ARF Engine Mount
Old 08-06-2008 | 06:48 PM
opjose's Avatar
opjose
Default RE: Super Skybolt ARF Engine Mount
Done properly, you should not see any difference.
If you put a 1/8" ply sheet over the existing one, merely decrement the firewall to prop driver distance by 1/8" as well.
As DaRock has pointed out, you should also add tri-stock to the area behind the firewall along the areas the firewall joins the fuselage ply.
The idea is to distribute any torsion or stress over a greater area.
While you are in there also consider adding some ply or hardwood stock behind and against the existing firewall for good measure.
