RCU Forums - View Single Post - Prop change or not? If so, recommendations?
Old 08-06-2008 | 08:39 PM
combatpigg's Avatar
combatpigg
Default RE: Prop change or not? If so, recommendations?
I wasn't aware of the 10x3, sounds like a good choice. What your plane needs is to shift into a lower gear, not flat out speed. The .25s that I have run get bogged down pretty easily. I would have suggested a 9x4.......you might find that the .25 likes to fly your plane with less load instead of more load.
