G62 ignition conversion?
Terry, just curious, do you have a prop adapter for the G62 that does away with the factory flywheel all together? If so, couldn't a guy use the CH Ignition module that has the coil built in?
That would be the lightest a G62 could be. May be less than 5lbs?
