RCU Forums - View Single Post - Instruction for Hangar 9 Edge 540 (1.20)
Old 05-18-2003 | 03:29 PM
RysiuM's Avatar
RysiuM
Default Instruction for Hangar 9 Edge 540 (1.20)
Hi Guys,
I have bought Hangar 9 Edge 540 (1.20). The plane is already build and looks solid. But I don't have any paperwork for it. Before I fly it I'd like to see, how it is supposed to be finished.
In this the tail configuration is: kevlar pul-pul for the rudder (one servo) and two push-pul elevator with long CF rods (two servos next to rudder servo). Please help me with the following questions:
1. What is the balance point?
2. What are the recommended servos (speed and torque). I'm not sure if HS-605 will be good for ailerons (I have a spare pair), and I'm planning to buy some Hitec digital for tail (what size?).
3. What is the recommended battery size (at 6V)
4. The wing is mounted by 4 nylon 1/4" bolts screwed directly into the wood. Is it enough? Will it hold the force i.e. of the "wall"?
The plane now has 12.5 lb with OS 3500 BGX. It's still within recommended weight but with wing loading 28 I will need to start thinking how to save the weight.
Any help, recommendations, comments are very welcomed
Anyone has the instruction to spare?
First picture shows how wing is mounted.
RysiuM
