RCU Forums - View Single Post - Instruction for Hangar 9 Edge 540 (1.20)
Old 05-22-2003 | 08:24 PM
RysiuM's Avatar
RysiuM
Default Re: Hangar 9 Edge 640 servos
Originally posted by RysiuM
Elevator. Two Hitec HS-625MG with push-pull CF tubes.RysiuM
These HS-625MGs don't hold the elevator. Bummer!!!
The case is, that per instruction hi rate elevator should move 3 inches up/down. I set it up with about 140% ATV. Then I setup low rate per instruction about 1/2 inch up/down. It took abut 35% ATV. Unfortunately these servos don't hold center well under the force. Now I can force the elevator 1/2 inch before servo holds it with the full power. Halt inch !!!! It's the full throw on low. I can't fly like that. My elevator will flap around on the flight (each side separately) so much, that I will not be able even to compensate it with ailerons.
So, sorry to say, I have no other choice than digital. Brrrrrr. I'm scared, but I don't see a better solution.
RysiuM
