RCU Forums - View Single Post - Instruction for Hangar 9 Edge 540 (1.20)
Old 05-23-2003 | 12:00 AM
RJConnet
Default H9 Edge
Is your servo actually moving as you force the elevator or is the CF pushrod bowing. I know the CF is very stiff but that is a fairly long pushrod if they are unsupported. Are you having the same problem with your aileron servos? If not, I would guess you are having pushrod troubles as the 625's have the same torque rating as the 605's.
