ORIGINAL: JohnMcGowan
Hey guys, I am starting on a Magic ( the original version) and am going to power it with a TT46 Pro with a mousse-can setup. This is what engine I have to use, so is this a good choice?
Anything I need to know as far as assembly? I would really like to use nylon screws to mount the wing, instead of the recommended rubberbands,.. anyone done this? Also, can I get away with using standard servos on all the surfaces? Any other tip/tricks would be welcomed.
Thanks in advance!!
John
Hi...I have been flying for 11 years...on my 3rd Magic, still new, deciding if I should electrifly it. My first 2 magics were worn out, gave them both away.
My setup.
Engine : OS40FP + mcp (home made)
Prop APC 11x4
Servo: JR BB standards all around.
AUW : 3.7 lbs
CG: 5.5"
Throw: Max deflection with expo (adjust to suit yourself)
Some mods were,
1. Cut off the servo tray, moved the throttle servo forward
2. Smaller fuel tank (6oz) located at the cg, found a tank that fitted nicely in the center bulkhead.
3. Batt / Rx installed just behind firewall
4. Engine was tilted so that mcp was inbetween the landing gear.
5. Operated on the wings to make it boltable, just 1 bolt at the rear and a CF tube as dowel infront.
Learnt to hover, harrier, rolling circles with this plane...its a VERY good machine, u need to get used to it. I loved it so much I scratch built a bigger one
http://www.rcuniverse.com/forum/m_58.../tm.htm#584250
Im sure u'll enjoy it.
regards
