RCU Forums - View Single Post - Prop change or not? If so, recommendations?
Old 08-08-2008 | 10:04 AM
brett65's Avatar
brett65
My Feedback: (18)
Default RE: Prop change or not? If so, recommendations?
ORIGINAL: spiral_72
Just an idea.... check your control surfaces.... primarily the elevator an rudder, to see if you have any up/down, left/right trim in it. You might have a CG or engine thrust line problem.
She will fly straight and level just fine, it just doesn't have any vertical power. It will only do small quick loops, not long drawn out ones.
