Items needed for building a kit?
a couple things:
I would buy some wood glue. The CA (superglue) is expensive and puts off alot of fumes. Many people develop alergies.... I use the CA to quickly spot bond parts and then use the wood glue to complete the joint. You will understand better what I mean as you are building your plane.
Make full size copies of your plans. (Kinkos)
I agree with the Heat gun. It makes the covering much easier.
Most kits require that you purchase additional items such as wheels...These items are usualy listed on the first page of the
instuction booklet.
Your instructions will tell you where to use which type of glue.
Good luck and enjoy.
