RE: problem with DA 50 engine
A few guys have had gasket blow outs between the carb and the isolator block or the block and the crankcase that reported that problem. I've also seen tygon swell and leak air on the barb that supplies pressure to the carb's pump. Be sure to use zip ties on ALL tubing connections to prevent this from happening.
